Quoted from Pin_Guy:When I said this was going to be an easy find I had looked at row 2 of your switch matrix, and can tell you the problem is going to be one of 4 switches, 22, 26 ,27 ,or 28.
Sorry, this is incorrect as I over simplified this. For example activation of column 2 would always pull row4 low since this switch is always closed. If you had a shorted diode in switch 64 (drop #4 right), this low going signal would activate column 6. with column 6 active during column 2 time, closure of switch 61 (Drop #1 Left) would cause row 1 to pull low and would be read as a closure of the Slam Tilt switch.
Actually, looking closely at your matrix, switch 44 may show up as a single switch multiple closure, since its closure, combined with SW24 your always closed switch and SW41 (mine popper) which will always be closed if the opto is unblocked, would cause a slam tilt if SW44 had a bad diode.
What can we rule out then...
You can rule out every switch in columns 1 and 8 as there are now switches in row 1 that could pull the row low. You can also rule out all switches in rows 3 and 5 since there is no way to pull these rows low during column 2 time to activate any other column switches.
