Quoted from whthrs166:First thing first... are you running Continued or factory software? I am running Continued but my factory software was 1.4 I am not sure that is the last version or not. If you are on factory software make sure you have the latest version. If your ball goes into a VUK and does not come out and the game does not search for it, then you must assume that the VUK switch or opto is made and the game sees it. Check that VUK solenoid and or solder connections. I would also put the game in switch edge test and check those VUK switches that the ball wont come out of. Then go to solenoid test and fire those VUKs with the test. It sounds to me that you caused an issue with the solenoid power string for those VUK solenoid. Go back and check your work (follow your footsteps)
The ramp flap issue can be resolved by removing the ramp and (Gently) bending the flap backward. Not sure on what you mean by "sold out" Broken perhaps? Post pics.
I tested and the optos at mine and saloon do not seem to be working. Solenoids fire ok in test mode.
I also noticed that the beer mug switch is not registering for some reason now.
I went back the steps I did, but I noticed nothing unusual. But then I remembered that I dropped the metal coil holder from the left flipper onto this board - the electricity was off, but could it have had a hit there (?) I removed and reconnected the connectors onto this board, but it did not help.
With the round protector I am referring to this round plastic next to the bad guy. It is larger than usual and I have only this tiny round protector there now.
Thank you for the tip on ramp flap. I will have to do it, once I get the pin in order.
