(Topic ID: 83005)
CC Continued--conversion details request
By StevenP
7 years ago
  • 8 posts
  • 6 Pinsiders participating
  • Latest reply 7 years ago by markmon
#1 7 years ago
I might be getting a CC soon (from its original owner), and if it works out I will be converting it to a CCC. Can anyone point me to simple/direct info on what's needed/best for this? I know I need a P-ROC, a PC, and want to add a color display. Looking for specifics on what type of PC (will a barebones motherboard be OK, and what I/O is needed?), what kind of color display is best, info on installing/mounting/setup, etc. I searched and read a bunch of random info, but still haven't found this clear, concise info. Thx!
#2 7 years ago
Pretty easy. Any PC core 2 class with USB port and headphone jack will do. I have winds 7 installed on mine. I picked up an LCD from goodwill for $25 and decased and mounted it. For audio you can go the audio route I outlined in the CCC software thread. I'd use a smart power strip to handle the PC and perhaps install a push button for power in the front if the cabinet somewhere.
For the PC, there are tons on eBay that work for around $175.00 shipped.
#3 7 years ago
Quoted from StevenP:
I might be getting a CC soon (from its original owner)!
Lucky dog!
#4 7 years ago
Quoted from markmon:
Thx! I actually have an old laptop with a Core 2 processor, 1.8GHz I think. All you need is USB and headphone jack? What size LCD is needed--something just bigger than a DMD, so it fits in the backbox? I'll check the CCC software thread too. Would be cool if I could mount the laptop and screen in the backbox, but I presume I need a standard video input for the monitor.
#5 7 years ago
Not following you on the mounting of an LCD in a CC DMD hole/the physical fitting proportions--have a pic?
#6 7 years ago
Eric sells an LCD monitor and correct mount for the game that plugs right in.
Might want to go that route to avoid guesswork/hassle.
Check the CCC thread.
#7 7 years ago
Two-Fiddy. But I don't have any left right now.
4 weeks later
#8 7 years ago
Quoted from NM:
I do not have a pic. I removed the case on the monitor which made it pretty small. I believe I gorilla taped the monitor into place and made a small mount bracket out of some crap I had using around. The whole process took about 30 minutes and has been solid. It was easy to position the colorized dot matrix window in the software.
