New Gottlieb Caveman problems!
So everything was working fine. Now when I turn it on, coin it up, hit the start button, I hear a click, click, click, and it doesn't try to shoot a ball out. It will do this over and over every 3 seconds. If I manually hit the targets they are working and the score is working but I cant get a ball to kick out. Also I notice that the 4 targets on the right side of the upper middle playfield will drop down when I push them, but once they are all down they will not pop back up. This is only the right side, the left side works great.
I get the feeling that when I push the on/off button on the bottom of the cabinet, that there may be something wrong with the switch because the game doesn't always start properly and sometimes the sound doesn't come on in the game, you have to go to the back, unplug the sound harness put it back on and then the sound will turn on.
Where do I start?
Is there anyone out there that goes through Caveman pcb's?
Is there any links out there on Caveman restorations or maintenance?
Please any help will be appreciated!
Thanks,
Steve
