In my Fish Tales the ball from the catapult does not hit the wire ramp. It aims way to high. Without the cover the top two wires are hit and the ball even hops above, so the ball almost shoots completely over the ramp. There is no way to adjust this much by bending the wires.
I tried to maximize the way of the catapult, so it will stop only short of the ramps. I also checked the coil and replaced the sleeve to be sure. No difference.
It appears the ball is leaving the catapult 'spoon' bevor end of way is reached. This may be the centrifugal force as the catapult is very fast. I tried to film it, attached you find a picture from impact. You can clearly see the ball being considerably higher then the catapult.
The ball sits fairly loose in the spoon and can be pressed down by 2mm (plastic then widens a bit).
What can I do?
