(Topic ID: 123926)
Catacomb Club
By AlexSMendes
9 years ago
  • 1,408 posts
  • 109 Pinsiders participating
  • Latest reply 61 days ago by cottonm4
  • Topic is favorited by 37 Pinsiders
7 key posts have been marked in this topic (Show topic index)
There are 1,408 posts in this topic. You are on page 29 of 29.
#1401 62 days ago
For anyone with a Catacomb that has a blown out and flaked bagatelle back box board, Mirco is now reproducing them. I got this one from TPF the other day. It looks fantastic.
Caution: Mirco has had problems with his clear coat in the past. I cannot speak to how durable the clear on this board is, but it looks very nice.
The one issue I have is that the dimples for locating the rollover switches are not located correctly (not centered to the slot) but it is something that is easy to fix.
#1402 62 days ago
cottonm4 so happy you picked up the mirco board! Every time I walked past it, I wanted to get it. Looked great in person!
#1403 62 days ago
Quoted from cottonm4:
For anyone with a Catacomb....
So is it actual wood?
#1404 62 days ago
Quoted from TheLaw:
9 or 10 plies. Real wood. You can see the grain in the wood. The OG board is MDF.
Pinside_forum_8083636_3820087 (resized).jpgPinside_forum_8083636_3820087 (resized).jpg
#1405 62 days ago
I can't imagine the clearcoat being much of an issue on that specific "playfield", right? It's not going to have near the same kind of stressors the a regular playfield would have.
#1406 62 days ago
Quoted from play_pinball:
There are posts that are being screwed to the surface so pooling is a possibility.
One issue that has come up with the way Mirco makes his play fields is that he does the graphics and clear coat first. And then he does his machine cutting. This leaves sharp unprotected edges along the sides of each cut hole. Taking a tip from Kruzman I will run a brush loaded with clear to seal in the cut edges.
#1407 61 days ago
Maybe ease them a little bit with sandpaper.
#1408 61 days ago
Quoted from slochar:
The issue, according to Kruzman, is if a play field is inked, then cut, then cleared, that the clear will cover the cut edges and seal the play field. Whereas, if the play field is cleared and then cut, the open edges allow moisture from humidity to creep in between the finish and the wood and do damage long term.
I can no way verify this but it sounds plausible. Considering it will not take all that much work to "seal" the edges I will do this on both this back board and on my Dragonfist play field.
$ 1,199.00
$ 3.00
Cabinet Parts
20eyes
$ 69.00
$ 125.00
$ 859.00
$ 400.00
$ 12.00
Third Coast Pinball
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/catacomb-club/page/29 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
