All of the back glass lift rails on my old Sterns are rusted badly so I have been busy replacing them with polished stainless steel lift rails that Gatecrasher makes.
The other item I am starting to replace is the white trim strip that goes along the sides of the classic Stern back glasses. I don't know about you but on all of my classic Sterns that white trim strip is just one more piece of plastic turned yellow from years aging and of nicotine exposure.
You cannot buy white trim strips. You can only buy trim strips in black. Some people are happy with the black trim strips. I'm not. I like the white ones but as I said, you cannot buy them.
I have found a solution. Here are 3 pics showing a comparison of the old trim vs. the new.
The old:
The new:
Side by side:
Here are the new white trims on the Star Gazer that I am building.
Some people like the black trim and I get that. But for those who like the white as I do, here is how you procure some white trim.
You go to Lowes or Home Depot and get a length of white plastic channel that is used as a border for shower walls.
This stuff. It is designed to cover the edge of shower wall material which happens to be 1/8" thick. Your back glass is 1/8" so the fit is perfect. The only thing you have to do is make the short leg of the channel a little shorter than it is; You can leave it as you bought it which is longer than what Stern used but if you have access to a table saw you can trim the short leg to the correct size.
Eight feet of this shower wall trim costs about $3.00. It will yield enough sticks to do both sides and the top of your back glass. $6.00 worth will allow you to put new white trim on three of your Stern back glasses.
Now, I need to put this on the other Stern threads.
