Hello All
Have a weird situation with a security camera that is connected via CAT 5 and uses POE.
This is the second camera now that, when you look at the physical connection, the pins on the one end of the connector appear to be burned.
I attributed the first camera to having water intrusion that may have caused this but now that it is happened again and water intrusion possibilities were mitigated with the replacement camera, unlikely.
Please have a look at the picture and weigh in as to possibilities. This camera is fed with a long feed from the main house. I have two other cameras with slightly longer feeds and they have been fine for years. CAT 5 cabling is running above ground. Only thing that I can surmise is that the feedline somewhere between the camera and where it enters the house has become compromised. Has a rodent chewed on it?? Don’t know.
I can tell you that when I replaced the original camera with the second one, it was fine for a couple weeks!!
Halo is always appreciated
George
Thank you
George
