Ok, so as promised - a short review. First the goods:
1 - The kit is pretty complete. So you really don't need much more to get started plating.
2 - The instructions are pretty clear. You do have to do some calculations which they show you how to do. But overall, easy to understand.
3 - The results are very good. I had a couple of streaks initially in my first batch but I'm pretty sure it's because I didn't rinse properly after I degreased the parts. Newbie mistake. Even still, the results were outstanding.
4 - Caswell's customer service is very good and shipping was quick. It was two days to my doorstep. When the kit arrived, one of my pots was damaged. I called them and they sent another with no questions. Also, when I was ordering I asked A LOT of questions. They answered everyone and were very knowledgable.
Now for the others (not so goods)
1 - It is a little labor intensive and time consuming. You have to clean the parts before you degrease them. In my case I have a blast cabinet and blasted the parts with glass bead. The smoother the parts are before you plate, the shinier they will be.
2 - This is not a set it and forget it process. You have to watch it for the entire 30-60 minute cook time. Which is not an issue, but you should not plan on multitasking too much.
3 - Cost. Still not sure it's cost effective because you can only plate so many parts before you have to order new chemicals. To put it in context, I think I'll be able to plate both four bank drop targets as well as the flipper mechs but then will have to buy more chemicals. But...I am doing it at home without having to send it out and getting very good results operating on my own timeline.
Here's a pic of my setup. My 16 yr old son came in and said I had been watching too many episodes of Breaking Bad..
