(Topic ID: 303072)
Casino high roller switch issue
By martymart
1 year ago
  • 6 posts
  • 3 Pinsiders participating
  • Latest reply 1 year ago by phishrace
#1 1 year ago
I have just replaced a number of blown transistors on the switch matrix on a stern high roller casino. As a result I now have all the switches working but now there are still a handful of switches that trigger 2 or 3 other switches on that column when a single switch is triggered in test.
This occurs in around 3 of the columns. This machine had switch issues when i got it. Now most of the issue has been resolved but I am not sure where to look next for this problem.
Any feedback on next steps would be great.
Thanks in advance.
#2 1 year ago
Quoted from martymart:
Thanks in advance.
If you are triggering one switch and one or tow other switches in that same column are triggered, you probably have a one or more row shorts somewhere. Each switch in that column should have a unique row wire going to it. Refer to your switch matrix diagram to find which wires you should be focusing on. If you need more help, post some more detail of which switch numbers are the problem.
#3 1 year ago
It sounds likely that it's a playfield issue, but since you did board work on the switch matrix, I would suggest you confirm that the problem is on the playfield and the board is working properly.
https://www.pinwiki.com/wiki/index.php?title=Sega/Stern_White_Star_Repair#General_Switch_Matrix_Testing
#4 1 year ago
Quoted from phishrace:
Sorry I should have mentioned that I have tested the board after the repairs and the matrix works as it should. So it is a playfield issue.
I am mapping out the problem switches now. I will then look for shorts or problem diodes.
#5 1 year ago
I have done some more investigation and now have an issue where if a switch on row 3 is triggered it also triggers a switch on the same column but in row 6.
I have removed the connectors for column 1 as this was also causing an issue across row 2. By removing the connector the issue across row 2 has gone but the other issue still remains.
Any advice on next area to check would be great.
#6 1 year ago
Sometimes disconnecting sections of each row and column between switches can help narrow it down. Keep in mind that switches may not be wired exactly in the order it shows in the manual.
Men
$ 18.95
Arcade Upkeep
Other
PinSound
$ 69.99
Pinball Shark
Shooter rods
$ 14.00
Nordic Pinball Supply
Decals
$ 52.99
Pinball Shark
Shooter rods
$ 85.95
Shooter rods
Gweem's Mods
Sound/Speakers
$ 6.00
Apron Envy
Protection
$ 76.00
Lighting - Backbox
Arcade Upkeep
Backbox
$ 12.95
$ 5.95
The Pinball Scientist
Protection
This page was printed from https://pinside.com/pinball/forum/topic/casino-high-roller-switch-issue and we tried optimising it for printing. Some page elements may have been deliberately hidden.
