(Topic ID: 358163)
Carving out a gameroom
By gandamack
82 days ago
  • 12 posts
  • 10 Pinsiders participating
  • Latest reply 82 days ago by gandamack
    #1 82 days ago
    I am really considering constructing a gameroom in a crawlspace under my house. Do you think it is possible? I would need a bigger entrance door than what is already there. Is it possible to tap into the heating and air conditioning ducts? I spoke with one contractor and he said that the job is indeed possible, but when I brought up the subject of construction permits, he said he did not do that. So I guess it would be a pay under the table kind of thing which is OK, but the part I am hesitant about is the non-permitted work in the event of a fire or even if I decide to sell the home in the future. He said he could do it for 12,000. Which is super low in today's construction market. I think if I was to go the permit method with a licensed contractor, then I would probably be looking at close to 120,000??
    IMG_2390 (resized).jpegIMG_2390 (resized).jpegIMG_2391 (resized).jpegIMG_2391 (resized).jpegIMG_2392 (resized).jpegIMG_2392 (resized).jpegIMG_2393 (resized).jpegIMG_2393 (resized).jpeg
    #2 82 days ago
    Looks like a good space so do it right. Start with a proper permit for the work being done (especially under home) and shop local references for licensed contractors on quote/bid. Good luck!
    #3 82 days ago
    I would go with a fully licensed contractor for something like that, and they should have no problem getting permits for the job if they are professional. This is your house, and besides the inherent risks of an improper job, having something like that will definitely affect the possible future sale of the home.
    Probably like just about any project, anything can be done. Its just a matter of paying.... I have no idea what the number would be, but probably closer to 120k than 12k.
    Also, I'm no expert or anything, but what's under there right now looks a bit suspect, especially some of that bracing. I know there are some Pinsiders who are contractors who know about stuff like that, maybe they will find this thread and comment.
    What's the total available height you have in there? Can't tell from the photos.
    #4 82 days ago
    Okay, here's the tricky part. Looking at those pictures, it's definitely possible, but you're going to need an entirely new support structure to make it happen. I can't tell if that's all concrete, or some of the supports are on dirt. With dirt, there's what's called the angle of repose. When something sits on the peak of a pile, the angle of repose is roughly 45º. The force from the column follows that as well, so you really can't dig out the dirt from under some of those columns.
    You will likely need to have an architect/engineer spec out a whole new beam system under there to do it safely. Honestly, given the option, i would build an attached structure next to the house.
    #5 82 days ago
    Thanks for the feedback. The beams are indeed in concrete. Height is approximately 14 feet (in the area I wish to construct.). The area kind of slopes upward, but was thinking that area would be walled off. I tend to agree with the advice given to obtain a professional contractor who gets the job permitted properly. Thanks again!
    #6 82 days ago
    If you have a 14' work area, I would keep to that area. Underpinning or digging out your basement would just balloon any cost estimates. Definitely have that project permitted. Having your house fall in is not worth the savings.
    #7 82 days ago
    I’d never do anything without permits. When it comes time to sell, you may be forced to UNDO all of the work which will cost an ass ton of money and be a major headache. It’s totally not worth saving a few K.
    About heat and ac, I find on a basement level it’s not very necessary. It stays cool in summer and warm winter due to being underground. You can always use a space heater and dehumidifier to control the climate a bit. Hope you get your game room.
    #8 82 days ago
    Check where your water table is before doing anything.
    #9 82 days ago
    How big (width/length) is the area you’re planning to finish? Hard to tell from the photos, but from what I see the area available to be finished doesn’t look very big.
    #10 82 days ago
    Quoted from gandamack:
    I am really considering constructing a gameroom in a crawlspace under my house. Do you think it is possible? I would need a bigger entrance door than what is already there. Is it possible to tap into the heating and air conditioning ducts? I spoke with one contractor and he said that the job is indeed possible, but when I brought up the subject of construction permits, he said he did not do that. So I guess it would be a pay under the table kind of thing which is OK, but the part I am hesitant about is the non-permitted work in the event of a fire or even if I decide to sell the home in the future. He said he could do it for 12,000. Which is super low in today's construction market. I think if I was to go the permit method with a licensed contractor, then I would probably be looking at close to 120,000?? [quoted image][quoted image][quoted image][quoted image]
    That’s the biggest damn “crawl space” I’ve ever seen!
    I’ve worked in the trades with some wild guys who have dug-out basements on the down low. They do phenomenal work, but if selling is at all on your mind, then you should get a permit and have it done right. Plenty of competent contractors don’t pull permits because some towns and building inspectors are idiots and REQUIRE you do things the WRONG way just because of outdated codes and their own hubris and ignorance.
    Just be careful what you’re getting into, ask around and always get multiple quotes!
    #11 82 days ago
    Is a standalone building somewhere on your property not an option? (Seems like that may be a “path of least resistance” type of way to go.)
    #12 82 days ago
    Quoted from Fatsquatch:
    Well the goal is to have room for six machines, a tv and a kegerator. Got about a working area of maybe 80 square feet? Maybe it is too tight? Ya, I could go for a separate building in the backyard. Maybe that is the way to go? I just figured, I had an area under the house that is vacant and bare. But hell it may be easier to construct a game room separate from the house.
