(Topic ID: 179933)
Card Whiz - question on special function
By njPinWiz
7 years ago
  • 7 posts
  • 5 Pinsiders participating
  • Latest reply 2 years ago by Animal
#1 7 years ago
Gottlieb '76 Card Whiz, am trying to determine if the "special" kick out hole function is working properly. When the 3 Joker sequence is made, the Rule Set says: Completing the 3 Joker sequence lights the hold alternately for special.
Key word is "alternately", not sure if it means the special goes on/off when the ball goes into the kick out hole...or, if "alternately" means special goes on/off when some other action is made (example, a lane or a sling is hit)?
Anyone know for sure how this is supposed to work? Thanks.
#2 7 years ago
with help from a friend I now understand that the special alternates between being on/off whenever a 10 point function is hit on the play field (either sling, or a passive side sling)...the F relay is activated every time a 10 point target is hit & that in turn triggers the alternating special.
2 years later
#3 4 years ago
One question on this...in 3 ball play the special lights as it should when all 3 jokers are made. In 5 ball play the special never lights after the jokers are made.
Is this correct or do I have an issue with my Card Whiz?
#4 4 years ago
In 3 ball play, special is constantly lit after 3 jokers are made. In 5 ball play, the special alternates on and off with every 10 points scored. I think the alternating switch is on match unit.
1 year later
#5 2 years ago
I have a card whiz and the eject hole special light does light up after the 3 jokers are hit for 3 ball play.
But, for 5 ball play after the 3 jokers are hit and 10 point bumper is registered, the light flickers for a second and goes dark. Once the ball goes in the hole, a game is rewarded.
...any idea why the light flickers on the 5 ball game, but fully lights on the 3 ball game?
#6 2 years ago
Quoted from Animal:
Inspect and diagnose this circuit with Alligator clip jumper wires
https://pinside.com/pinball/forum/topic/gottlieb-big-shot-repair#post-6305153
http://www.planetimming.com/Pinball/troubleshooting/EM%20Troubleshooting.pdf
http://www.pinrepair.com/em/index3.htm#features
Example of a pinsider actually doing this https://pinside.com/pinball/forum/topic/red-baron-tech-question#post-5858156
#7 2 years ago
Thanks very much for the info! Will be rolling up my sleeves and see what I can find - dealing with a learning curve too, but its all good!!
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/card-whiz-question-on-special-function and we tried optimising it for printing. Some page elements may have been deliberately hidden.
