Car light bulb / Pinball hack for license plate light bulb
(Topic ID: 235751)
By bonanza
6 days ago
  • 10 posts
  • 8 Pinsiders participating
  • Latest reply 5 days ago by ryanwanger
    #1 6 days ago
    So my Toyota Highlander license plate bulb was out and I decided to replace it. Replacement type was W5W. I pulled it out and thought, hmm this looks like a pinball bulb. I think I have a few of those laying around. Go digging in my spares and out comes a 12V 555 base bulb. did it work? Why yes it did!
    I could have spent $6 to $20 at Autozone or I could shove a $1 LED pinball bulb in.
    I just laid the old bulb and a spare bulb together for that first picture. The bulb I used had a few more SMDs on it.
    P1030044 (resized).JPGP1030045 (resized).JPGP1030046 (resized).JPGP1030047 (resized).JPG
    #2 6 days ago
    Hi, a 555 is usually a 6.3 volt lamp. Unless there is something unusual about the Led you put in, you are probably overdriving the led with double its rated voltage. It will work, but its life will be very short.
    #3 6 days ago
    Quoted from JP:
    Yes it will work for a short period of time and then it will fail and start to flicker-need 12V LED
    #4 6 days ago
    Same in 12V....Base size is only difference, so it needs to be tight...
    T10....10mm base, what you used,
    T15 .....15mm base, full socket contact.
    12V Flasher Bulbs for Pinball are fine, and yes, $1-$2 in the Hobby,
    up to $20 for License plate, and $75 for High end Car, 12V interior dome light
    #5 6 days ago
    need another current limiting resistor for a 6v LED running on 12v. If you bend out the leads and take apart the LED you might have space to cram one up in there.
    If you look on eBay or AliExpress they have crap loads of 12v LEDs intended for vehicles. You can probably find a 99cent with shipping one to try out.
    #6 6 days ago
    my old vw thing uses 555 and 89 bulbs, a pleasant surprise, a bulb was $8 from the vw dealer or .50 from pinball life.
    #7 6 days ago
    Yes sorry I was typing fast and all excited. A 906 socket 12VDC 5 SMD white bulb was used. In the first picture I just laid the old bulb and stray LED bulb together.
    I think they are coin takers 906 Super 5 bulbs so maybe $2 each.
    #8 6 days ago
    Yep I did interior LEDs for a Toyota Solara and used mostly pinball bulbs. All were 12v versions from Comet. Worked great. Definitely don’t use standard 6V pinball bulbs without modification. Now I have a new Highlander and will do that one next when I get time.
    You have to be a little careful when convert from incandescent to LED on interior lighting so you don’t get it too bright or too dim. As a general rule of thumb an LED wattage is about 15% of incandescent to produce the same brightness (lumens). So for a 20 watt incandescent a 3 watt LED should be about the same brightness. The LED auto people usually think the factory lamps are too dim so they will go for brighter LEDs. They like to add extra lighting in various places as well. It’s a whole thing.
    #9 6 days ago
    I took some old bottles, and used both my Op-Max, and 2835 in sockets for landscape lighting on a 6.3V
    Transformer.....super easy and fast, and with the bottles upside down, no water issues...
    (I did silicone with small drainage, to keep nesting bugs out later.....Blue Ice Tea Bottles,) but lots of creative lighting projects here...cabinets, fountains, all done with Comet LEDs
    #10 5 days ago
    Quoted from OLDPINGUY:
    Sounds awesome! Pics?
    $ 5,799.00
    Classic Game Rooms
    $ 200.00
    Professor Pinball
    Pinball Wheezer
    $ 69.99
    $ 445.00
    MI Pinball Refinery
    $ 169.95
    Pinball Pro
    $ 129.95
    Pinball Photos
    $ 7.00
    Various Other Swag
    Project Pinball Charity
    $ 999.00
    $ 839.00
    Pin Monk
    $ 19.95
    $ 66.95
    $ 79.95
    $ 48.00
    $ 159.99
    $ 69.99
