Hey 4Max, (Now hey to everyone out there)
About a year ago you posted a picture of your captain fantastic machines game over interlock relay on this thread
I recently bought a Captain Fantastic machine and I have had it about a month when all of a sudden the machine continuously resets itself and the score motor never stops and the drop targets keep resetting continuously.
I really do want to learn about this machine and I know it will take time. I opened up the machine, turned it on, then hit the start game button and noticed my GAME OVER INTERLOCK RELAY sparked when it first came on (only sparked once, does not continue to spark during each reset) Anyway intuition told me that just maybe that isn't right and it could be the heart of my problem. I took a picture and tried to compare it to yours but again I'm not terribly sure what I am looking at.
I have attached pictures of the GOIR when the power is off and when the machine endlessly cycles. The first picture is when it is off. Could you look at them and tell me if you think I might have a problem here? Any help would be soooooooooo appreciated. Also looking at them, do they look really dirty? They do to me, what is the best way to clean them?
Sooooooo Max was kind enough to reply and send me here. Any help would be greatly appreciated. What does "pull the plastic" mean? Yup.....newbie!
Bland in Atlanta
Hi Bland
Well first step is to create a new thread in the EM Tech section, you will get lots of help. Plus I've recently moved house so am still trying to find where all my schematics are. By the way, you will need a CF schematic sooner rather than later. And not sure hoe much help i can give with all the other stuff going on.
But, had a quick look, and your GOIR does not look in too bad shape, but yes I would start here. Manually (with the power off!) just pull the plastic as if the coil with white label is pulled in (the green label coil will keep it there) and then pull in the green one which releases the white one. The 7 switches must change state - meaning be obviously closed or open. You will need a flexstone to give them a simple clean. This place has everything you need http://www.pbresource.com/tools.html
So, start a new thread. copy in your questions and photos (they are good!) feel free to copy in my response, and then let the all the experts on the site guide you - initially it is a little overwhelming but I assure you over time it all falls into place.
