I recently picked up my first pin from a friend that was moving and had to unload it. It's a coin-op and looks like it's seen some heavy use. When I got it, it started up and ran fairly well, but the rubber was wasted, some bulbs are out and only the two lower flippers work (the left one is very weak and only serves to send the ball over the the right one for a righteous launch). I've gotten some great info already from the Pinside forums, picked up the manuals/schematic and started the cosmetic restore - got rubber from Pinball Resource, cleaned playfield and replaced rubber. since the machine was working pretty well, I've been playing it and getting more familiar with it, but recently a couple of issues have come up.
Last week the playfield lights went out, but otherwise the machine kept working. Per recommendations, I've pulled and reset the Jones plugs under the playfield, but no luck. Today I pulled the Jones plug on the side panel and cleaned/reset it - when I turned the machine back on and pushed the play button, a loud hum came from the back box. I've heard this before when a ball would get stuck behind one of the old rubber rings and keep a switch open. I opened the back box and can see that there appear to be a couple of switches on the 100 Point coil that are sparking and staying closed (see attached images).
I'm not very good with electronics, so haven't been able track the issue down in the schematic and I'd appreciate any help before I burn up anything or do further damage. I don't know if it's relevant, but when in the process of cleaning the Jones plug, I lifted the playfield up and stood it in 'service mode' (per a video I accessed on another post) instead of propping it up with the side rod - maybe this dislodged something?.
Thanks in advance! - I look forward to replies and will be following up as the restore progresses.
Bill
100 point coil switched spark (resized).jpg100 point coil switches flash (resized).jpg
