New! Dark mode!
(Topic ID: 144149)
Captain Fantastic Lamp Problem
By troxel
  • 6 posts
  • 4 Pinsiders participating
  • Latest reply 4 years ago by troxel
#1 4 years ago
I replaced the pop bumpers along with new light sockets and now having problems with the lights. The only lights working on the playfield are the ones connected to the blue wire. If I jumper the blue wire to the red/yellow wire, then they all work.
Getting zero ohms from the metal wire to both the brown/white and red/yellow. (Both wires that connect to the pop bumper socket). I looked to see if the metal wire was shorting on the pop bumper bracket, and it wasn't.
Not sure what's the best method to troubleshoot this? Hopefully something easy.
#2 4 years ago
I would start with the ALT Relay
#3 4 years ago
Sorry for the dumb question, but where is the physical location of the alt. relay? Nothing is labeled inside the game.
#4 4 years ago
Hi troxel
Whenever You WORK on the pin: UNPLUG the Line-Cord ! Do not only toggle the Main-Power-Switch, do pull the Line-Cord. I want you to have a look at the fuses - they are neatly packed side by side - ONE fuse is for 110 VAC, I do not want YOU touching 110 VAC Power.
ipdb.org has a schema: http://www.ipdb.org/machine.cgi?id=438 - I must make a copy of the schema (down) onto my computer: "Right-Hand-side" Mouse-Click -> Save Target as ...
I read your description and I look at the schema. At schema-A-4 / B-4 I see TWO fuses (of 15 Amp). The first fuse then has Wire-Blue feeding playfield-lamps. This fuse is good. So the other fuse is in question.
I see (schema-B-2) the 8 Amp fuse for 110 VAC. At E-3 / -4, F-3 / -4 I see the 10 Amp fuse for the 50 VAC (Relays and Units). I do not see more fuses in the schema.
Unplug the Line-Cord. Look for the fuses. Can You find the 15 Amp fuses ? Take them out, have a close look at the fuse-holders - clean ? good (nothing broken) ? wires soldered-on ?
Put the "good" fuse (wire-Blue) into the socket of the other fuse. I cannot clearly see in the schema "what color": Is it "80" or "90" or "50" ? Well, on the other lug these fuse-holders have the same wire soldered-on ...
Plug-in the Line-Cord and start a game -> Do other lamps light-up ? If so: the "fuse in question" is shot -> get a new one.
If not (so): We must follow the wires -> check Switches on Game-Over-Relay.
Please report, Greetings Rolf
#5 4 years ago
To find the alternating relay, with the playfield lifted, hit a rebound rubber repeatedly while searching underneath for the relay, you'll find it rather easily, no label needed. It should be turning on and off. May as well clean the 2 switches the 50 wire, (white wire), switch blade tranfers between when you find it.
Since both the 13 and 65 wires show nothing, I'd check the switch that the 50 wire, (white wire), goes to at the game over relay. Bally added this switch to turn off feature lighting at game over.
#6 4 years ago
Such good information from everyone. Thank you. Boatcat was right with the switch that turns on and off the feature lights. Game is now working the way it should!
2,300 (OBO)
Manalapan Township, NJ
$ 22.50
Third Coast Pinball
$ 3.00
Cabinet Parts
BK Pinball
$ 7.00
$ 24.75
The MOD Couple
$ 42.00
$ 69.99
$ 21.00
$ 11.95
$ 5,899.00
Little Shop Of Games
$ 199.00
Lit Frames
Playfield - Plastics
Ramp-O-Matic
$ 48.00
$ 19.95
$ 209.99
$ 17.95
$ 5.00
$ 369.00
The MOD Couple
$ 7.00
APB Enterprises
