Here's another CF problem. My knocker doesn't fire. I see that it is fired by the Credit Unit EOS switch which closes when the Credit Unit step-up solenoid fires. When I close the EOS switch manually, it fires. There are three switches in one stack on the Credit Unit. The top switch is the Credit Unit Limit and is NC, the middle and bottom switches are both called Credit Unit Zero switches and are NO with Zero in the credit window. The "Same Payer Shoots Again" insert board and playfield lights come on when a Replay is hit, but not the knocker. I also want to set this game for Free Play. The Credit Unit step-up coil doesn't fire for an unknown reason.
