I removed the ball gate for corrosion removal and polishing, just the gate and nothing more.
Upon reinstallation the relay Buzzes with an intensity I have never seen on a relay before.
I cleaned the assembly to check for what might be causing the issue. Still no change.
I adjusted the switches so that they are helping to move the the relay plate into the on/locked position. Still no change
I tried activating the relay without the spring to see if the spring tension somehow became too tight and the same vibration remained no change.
The relay plate and the entire gate /Pivot arm mech is clean and free moving with easy activation so the relay is not getting anything to make its job harder in other words nothing is binding and all is in perfect alignment.
Above the playfield the ball gate is vibrating back and forth at a tremendous pace and when it strikes the wood rail it sends vibrations through the cabinet.
The buzz is louder than the chime unit and the vibration is stronger than a shaker motor.
The only thing done originally was to remove just the gate which came off with ease. The allen retaining screws were not frozen so the unit came out as easy as a flipper bat.
Can the relay just have given up the ghost ?
If I try holding or touching the relay mech anywhere to quiet it down it does nothing the vibration is too severe.
I tried to be a detailed as possible with info. I never had this happen before. Any Ideas? I can take a vid over weekend if this doesnt get resolved by then
