Just finishing up a full restoration. Went smoothlly, new playfield, cab redone and only had one switch issue. I am having a problem getting the right outlane ball gate to work properly. I reassembled exactly as she came out, simple bushing with a pawl that has a pin that slides in a shaft that allows to gate to normaly pop out and then return when the right outlane is triggered. My problem is I cannt get the gate shaft correct. I am getting too big a range of movement. When i set it to the right for opening where it doesnt quite hit the woodrail, when it returns it flies back and closes off the inner lane on the right. I have included pics and was hoping someone would share apic of theres so I can compare. Lot of slop in the busing but those arent repairable that i know, but that shouldnt cause an issue. Any help or guidance is appreciated.
20221219_140730 (resized).jpg20221219_140751 (resized).jpg20221219_140759 (resized).jpg20221219_140808 (resized).jpg
