Capt. Fantastic won’t start multiplayer games
(Topic ID: 207383)
By Doot77
1 year ago
  • 10 posts
  • 2 Pinsiders participating
#1 1 year ago
Ok, so like it says in the title my CF won’t allow 2+ player games and I’m looking for advice on what to check as I’m a bit lost on EM repair. I also don’t have a schematic and honestly am not very familiar on reading them in the first place.
A few things I’ve checked and find odd that may help in pinpointing the issue. The Coin unit won’t advance to add 2,3 etc players. If I manually adjust the Coin Unit for a 2 player game, the game won’t advance the ball count unit, it will go through all 4 players on ball 1 (even though a 2 player game was started) and never advance to ball 2. If you play a single player game the ball count unit advances as it should. Thanks in advance for any help.
Matt
#2 1 year ago
Bump for the night crowd.
#3 1 year ago
Quoted from Doot77:
(There's a schematic on ipdb.org.)
When you try to add a 2nd player does the Credit Relay fire, and does the Score Motor turn? Assuming they do, let's look at the Coin Unit which should advance to add a 2nd player:
When you hit the credit button for the 2nd player, does the Total Play Meter advance? If it does, the problem is that the normally closed side of the Make/Break switch on the Reset Relay is open. If neither the Total Play Meter nor the Coin Unit advance for a 2nd player, the issue could be in one of the other three switches in red in the schematic.
/Mark
#4 1 year ago
markg you were right on with the reset relay, a clean and adjust and I’m now able to add players 2, 3 & 4. However what I had assumed was all 1 problem is apparently 2 issues. The game still will play through all 4 players even if only a 2 player game is started. It actually gives player 4, 2 balls before advancing to the next ball in play and starting back with player 1. 1 player games advance through balls correctly.
#5 1 year ago
Quoted from Doot77:
I'm not familiar with the Bally Player Up Unit but it looks like it steps up once for each player for each ball, then resets to player 1 for the start of the next ball. (The Gottlieb Player units on the other hand only step in one direction and skip past the non-playing players.) So here is the relevant piece of schematic for the Player Up Unit:
The right side shows that when the ball drains and the Outhole Relay fires, a pulse gets sent through a Make/Break switch (in red) on the Player Reset Relay to either the Step Up or Reset solenoid on the Player Up Unit. The Player Reset Relay on the left (in red) should fire when the Ball Count Unit advances.
I suspect that your pulse (generated when the ball drains) is mostly getting sent to the Player Up Unit Step Up solenoid, taking you to player 4 every time. That's probably because either
- the Make/Break switch on the Player Reset relay isn't adjusted properly or,
- the Player Reset Relay isn't firing when the Ball Count Unit fires, perhaps because the Ball Count Unit EOS switch isn't adjusted properly.
/Mark
#6 1 year ago
Ok so from what I can see the ball count unit is never energized until you’ve played thru 5 balls( 1 for each player and 2 for player 4). Coin unit then activates and the player reset relay gets powered and it moves to ball 2.
The player up unit activates after each ball, player 1-4 even if only a 2 player game is started. The exception of a single player game where all functions work correctly.
#7 1 year ago
Quoted from Doot77:
Aha. That helps. Check this out:
It looks like the Ball Count Step Up solenoid should fire when the Player Up Unit disc is on the last player and the Outhole relay fires. You say it works fine for a 1 player game. In that scenario, the pulse to the Ball Count Unit Step Up solenoid goes around the Player Up Unit disk, through the Gray-Red wire and through the Coin Unit Disk. For 2 and 3 players it misbehaves, which would require the pulse to go through the Player Up Disc and through the Coin Unit Disc.
The problem may be that the pulse is getting lost in either the Player Up Unit disc or the Coin Unit Disc. Since the Ball Count unit does eventually fire, it seems that the Player Up Unit disc is advancing and eventually connecting to the Ball Count Step Up solenoid by bypassing around the Coin Unit disc on the Orange-White wire. That makes me wonder about the Coin Unit disc (in red). It seems to work fine in the Player 1/reset position. But does it advance properly and make the connections for multiple players? If the wiper on that disc steps off the rivet for player 1 but never lands on the rivets for the other players, that could explain what you're seeing.
With the power off you should be able to put the Coin Unit disc in position for various numbers of players, then check for a very low resistance (not just continuity) between the Orange-White wire and the three wires on the opposite side (Gray-Red for 1 player, White-Brown for 2 players, and White-Yellow for 3 players).
Alternatively, you could start a 2 player game and put a jumper between the Orange-White wire and the White-Brown wire and see if that plays correctly.
/Mark
#8 1 year ago
Coin Unit seems to check out good, doesn’t have rivets, it’s a circuit board style. No resistance on 2 & 3 player settings and jumping org-wht and wht-Brn still has same symptoms. What should I be looking at on Player up unit?
#9 1 year ago
Quoted from Doot77:
Same basic idea. Is there near zero resistance on the Player Up unit between the Grey-Red wire and the White-Brown wire for player 2 on a 2 player game? Or between the Grey-Red wire and the White-Yellow wire for player 3 in a 3 player game?
Taking a step back, you're trying to verify that there's a good connection between the 3D score motor switch (Grey-Red wire) and the Ball Count Step Up solenoid (Orange-White wire) in each of these cases:
- 1 player game, Coin Unit disk in position 1, Player Up Unit disk position doesn't matter
- 2 player game, Coin Unit disk in position 2, Player Up Unit disk in position 2
- 3 player game, Coin Unit disk in position 3, Player Up Unit disk in position 3
- 4 player game, Coin Unit disk position doesn't matter, Player Up Unit disk in position 4
These are the situations that should cause your Ball Count to advance but only the 1st one seems to work reliably. Checking the other three paths might reveal the problem.
/Mark
#10 1 year ago
Ok markg we have success, I tested gray-red wire to white-brn set on 2 player and also to white-yellow for 3 player and had no connection so after looking around I found the wiper arm was a little loose and could get a beep if I pushed it with my finger a bit. So I removed the wiper arm assembly and adjusted that arm and now it correctly plays 2, 3 player games with correct amount of balls etc.
I really appreciate the help, I definitely couldn’t have done it without your help. I really need to learn how to read those old schematics some day. Thanks again!
3,295
West Chicago, IL
€ 3.95
Multigame
$ 21.00
3,295
West Chicago, IL
$ 10.95
Apparel - Unisex
Pinball Wheezer
Apparel - Unisex
Project Pinball Charity
$ 99.00
Hardware
Pappy's Pinball Palace
$ 139.00
Displays
PinballSolutions.eu
$ 119.99
$ 146.66
Medisinyl Mods
$ 129.95
$ 7,199.00
Operation Pinball
$ 6,995.00
Flip N Out Pinball
$ 76.95
Lighting - Backbox
$ 50.00
