During play, one of the pop bumper skirts stuck in the down position due to the playfield protector I have installed, I noticed it when the ball drained and the ball count didn't cycle to number 3. I've replaced the the burnt out pop bumper coil and all the coils/relays in the bottom of the cabinet can close and open, none burnt up, including the Game over interlock relay in the cab. After the fix and powering on, the machine is stuck on ball 2, even when I manually change the setting for Game Over interlock relay. Is the coil/relay I'm looking for in the backbox? Where should I look? About a third of the relays in the bottom of the cab are not labeled so I don't know which one is the ball over switch/relay.
