the bottom right flipper on my Capt Fan was very weak and would barely move, and the upper right would rapid fire. I replaced the EOS switch and coil on the bottom right, and the EOS switch on the upper right.
Now the bottom right flipper works perfect, but the top flipper fire until it reaches the end of its stroke and returns to start point. If you hold the flipper button in, the bottom right will stay up, but the upper right will not as it only fires for a second then quits.
I am not an electro tech by any means so I need your help as this is driving me crazy. I took photos of the wiring before I touched it, and I am pretty sure it is correct still, but perhaps I got a wire wrong.
