Hi futurepinhead
may I read from Your post-10 and post-11 "can start a 1-, 2-, 3-, 4-Player-Game" ?
Great - You report in post-9 "testing with the tip of a screwdriver --- and the Game-Over-Relay trips". The test was for "is there continuity through all the connecting wires ?" - and Yes there is continuity so we get to the next questions "is the switch (contact-points) on the Lock-Relay good ?" and "is the switch (moved blade) adjusted correct ?". I use a rough cardbord or very-fine sandpaper to clean the surface of a contact-point mounted on a switchblade.
The switch on the Lock-Relay (You did the test with the tip of a screwdriver) is a very special switch - it is a Normally-Closed-Switch AND MUST be adjusted to open late, very late. Toggle-off the pin, unplug the main power cord - with a finger press the armature on the Lock-Relay and watch the switchblades of the switch --- as You slowly, constantly press the armature You should see: The "nylon-ladder mounted on the armature" moves one blade of the switch --- AND THE OTHER BLADE (of the switch) follows, has still contact with the one, moved blade. And then almost to the end of travel / Your moving the armature: The switch opens as the one, moved blade moves a bit further. Please check this moving of the blades.
Theory - You toggle-on the pin - current starts flowing to the Coil on the Lock-Relay (to make the Lock-Relay to pull in) --- and at the same time current starts flowing to the Trip-Coil on the Game-Over-Relay (to trip the Game-Over-Relay (((if it was not tripped at the time You toggled-off))) ).
In the wiring to the Trip-Coil on the Game-Over-Relay is a SWITCH on the Lock-Relay - opening, cutting current to the Trip-Coil on Game-Over-Relay. We want to help the Trip-Coil - we adjust the SWITCH on the Lock-Relay to open LATE, very late (((BUT the switch MUST open))).
In another topic I was writing about "self cleaning" of switches - I there wrote about the "50 percent rule", unfortunately I there did not write about Lock-Relay-SWITCH --- the Lock-Relay-SWITCH should be adjusted "about 80 percent of travel the two blades shall have contact - then finally the SWITCH opens". May want to read this: https://pinside.com/pinball/forum/topic/1965-bowl-a-strike-crazy-at-startup#post-3231326
Thanks for the video (post-11) - by now I do not have an explanation to the phenomena - I hope "your checking / adjusting (open late) the SWITCH" makes the pin to act normal. Greetings Rolf
