(Topic ID: 258327)
Capt Fantastic 100,000 points error
By Cardsrulelt
    #1 3 years ago
    So just on my Player 3 half the time when it reaches 20,000 During normal play it buzzes 100,000 points. Anyone know what could be the reason and how to fix it?
    #2 3 years ago
    Did you check the score reels and switch? from what i have read majority of the time needs a good cleaning and switch sometimes needs a bit of adjusting
    #3 3 years ago
    The 10000 point scoring units for each player should cause a 100000 point relay to latch when it rolls over from 9 to 0. Pretty simple mechanism in the grand scheme of things - you'll just need to check the 10000 unit for player 3 and check this latching behavior. Probably either needs a cleaning (as suggested above) or something is botched/shorted/not contacting as intended and it's closing the latch path on 1 to 2 instead of 9 to 0.
    #4 3 years ago
    This was just discussed in another post and as noted here in post 3, one of the sw. gap was too close.
    This page was printed from https://pinside.com/pinball/forum/topic/capt-fantastic-100000-points-error and we tried optimising it for printing. Some page elements may have been deliberately hidden.
