New to this site. First machine. Had it working 10 years ago but suffered storm damage in storage.
Now got it working again. but burned out cement risistor on Hold Relay. Schematics do not show it that I can see. Lights did come on then off a couple times before I replaced the burnt resistor. I replaced the resistor the lights came on the went out a couple times now lights don't work at all but game plays. (Will be checking fuses again and all pin connection) Just temporaraly installed a 50 ohm from Radio shack "when the lights did work" The game stayed in TILT before I replaced the resistor but I did look at all POINTS and clean and adjusted the ones that looked like the needed it. Now the game is not in TILT but I have the above mentioned light problem. LOVE working on this machine but can't wait to get it working and buy another EM machine to work on again. List of things to do. Fix lights, replace the zipper flipper relay (toasted) rebuild the right flipper. Eventually repaint the play surface and box. YAY. Basically What is the size of the cement resistor? What does the resistor control? Could the wrong size resistor be the cause of the light problem?
