(Topic ID: 154662)
'72 Williams/United Cape Cod shuffle alley and proper repair order
By steviechs
8 years ago
  • 7 posts
  • 2 Pinsiders participating
  • Latest reply 8 years ago by steviechs
    #1 8 years ago
    I just picked up a 1972 Williams/United Cape Code shuffle alley from a guy looking to make space. It was an OK deal and included delivery. He said it was his parents and in the basement for years, but it looks to be in rough cosmetic shape. There are city operating approval stickers on it from the 90's so I'm assuming it was in commercial use for some period of time. I've done an quick inspection of the game - no fuse issues, no burnt coils, turns on, resets pins on game start. That's about as far as it goes. The GAME OVER light automatically comes on at Frame 1.
    I've checked the manual which indicates that if this is the case, I should check the Lock relay, Lock switches, Tilt, and then the Frame Stepper. I believe the Frame Stepper is not resetting correctly. However, there are a handful of other issues and I'm not sure the order in which I should try to troubleshoot these. Perhaps one issue is causing part of another. Also some require some work which I think would be easier with the unit dismantled so maybe those make sense to do first?
    Things I believe I need to fix:
    • Frame stepper doesn't appear to reset to the proper location
    • #1 Pin hanger is broken so the pin itself won't retract.
    • Alley rollovers need contacts clean and some reset. Some stay stuck 'down' when activated. Others in the back row don't trip to indicate it's the next shot.
    • Game Select missing button. Manually activating the contact doesn't change the games (but adjusting the Game stepper manually does)
    To fix the pin hanger, I think I need to take the alley out to then let me take the pin deck out. Since this means disconnecting the plug connections, so to me I'd do this first before troubleshooting anything electrical? Is there a way to get into the pin mechanisms without taking the whole game apart?
    It seems like I'd be in the same situation to clean and fix the rollovers. There isn't enough space under the game and working on my back is less than ideal. So I probably need to adjust all of those with the alley removed and flipped over? Are the contacts the only part that provides the resistance to push the rollover metal wire back up?
    I'm going to take the clean the frame stepper according to the steps on http://www.pinrepair.com/em/index2.htm#steps. I feel like this would be the last thing to do?
    Once I can get a regulation game to play without errors, then I'll focus on selecting a different game.
    Does this all sound right? Located in Metro Detroit.
    #2 8 years ago
    I found the directions in the manual for the pin deck access without disassembling. 2 screws in the back box and two under the lower back glass and it slides right out.
    #3 8 years ago
    Hi Steviechs
    you are gonna want to go through the whole machine and tighten switch stacks, clean/adjust switches, clean/lube all the step units, and go through the score motor board and switches.
    if you do not, you will be chasin your tail for ever.
    take the lane switch roll over wires out, and clean/polish them. and yes, the switches are what brings them back up. they all need to work correctly.
    you gotcha a multi game player there. that means, everything talks to everything else for proper play.
    everything has to be working right, or every time a step advances, you will get a different result, but all will be not good.
    take your time and go through everything, and the shuffle will come to life.
    skip a few things, and, well... how much hair do you have?
    #4 8 years ago
    Thanks Dr_of_Style. I realized as I started digging into the game a few of the things you mentioned; most notably that everything is tied together. Slowly addressing each item. 2 questions though:
    Quoted from Dr_of_Style:
    I tightened all the switch stacks and adjusted a few contacts for the rollovers. This seemed to make all of the rollovers work as expected. When you said to take the wires out, are you referencing the metal rollover wire or something else?
    Is this each players scoring unit? These are less like steppers. Do these all get cleaned the same way as a step unit?
    #5 8 years ago
    Quoted from steviechs:
    The metal bent part that the puck rolls over.
    Quoted from steviechs:Is this each players scoring unit?
    no, it is the motor in the bottom.
    and yes, the reels are much the same as the step units, and all must be serviced
    #6 8 years ago
    I cleaned the steppers and things seem to be working much better. However, in a multi-player game the player stepper only resets 1 or 2 players back. The stepper looks to hold in the reset open position to go back to player 1, but the spring doesn't seem to be wound enough to get it back to that spot. What's the right way to adjust that tension?
    Also noticing the the game switches on the first pick throw only. It doesn't change after that. I can manually replicate this if I start a new game and hit the back row rollover relay. I see the 1st ball relay close and the score motor spins but the game stepper also increments 1 spot. Any ideas on what might cause that?
    #7 8 years ago
    I woke up with some clarity on the required fix. When I cleaned the unit and had the stepper off, I think that I pushed the shaft to hard which allowed the gear to unwind by a revolution. I simply loosed the nut on the wipers, pushed the gear back to get past the reset catch position, and wound the coil spring 1 revolution. Tighten the nut and resets like a champ.
    This one was a mystery because there isn't currently a button for the Select game. However, when I opened up the coin box I found a mangled switch for game Select. I did my best to straighten out the leafs and align the contacts. I haven't seen the game switch issue since.
