I picked up a PM and discovered it had various problems and issues.
The first and major issue is that when the ball goes up into the stage area it sometimes drops into the cabinet. I found a service bulletin online that details this and says to bend a back plate near the elevator input so I am going to try that, though it is a pain to get into that area.
Also the diverter arm does not match the drawing in the Manual as far as the mounting set screws. It shows them beneath the top of the arm yet they are ABOVE and the diverter is cocked not straight. The wand diverter has the mounting set screws on top like the manual shows. It actually looks like the same diverter arm is used in both areas with the stage diverter actually being flipped over.
Here are some pics and captions for both.
The second issue is when the ball actually enters the stage for levitation. The curtains open , the music plays, yet the elevator remains stationery . After ~ 4 to 5 seconds the elevator does start to move upwards and the ball rolls out to the right side wire lane.
The switch test shows elevator lift up and down switches in the Closed positions when running the switch diagnostics. I cannot find these switches under the playfield. Does anyone know where they are? I suspect they may be part of the elevator assembly and not on the playfield. They are switches #58 and 59. I found a connector under the playfield and it may lead to them. Disconnected the connector but SW 58 and 59 still show closed.
Finally the fake elevator ball is missing. Anyone know where I can get one or can I make one?
There are a few other switch issues at the right top slingshot and left bumper slingshot switches. These should be easy enough to fix so no real problem here.
