Hi all!
I’m not sure if this the correct place to post this, but I’ll give it a shot. I’m diving into MPF in hopes of rewriting some rules on my Capcom Breakshot. Like WPC, there is a serial port connecting the MPU to the driver board, however, it is a 50 pin ribbon cable vs the 34 pin located on the PROC and WPC. 25 pins on the ribbon are used on the Capcom board and the remaining 25 pins are grounded. My question is, is the output data driver specific to that header or could a driver be written to bridge the data output by using an additional header and then a breakout board be used to reroute/combine to a 50 pin? I’m quite certain my terminology isn’t correct so please forgive my ignorance. Any help/direction would be greatly appreciated!
TLDR: I want to connect a PROC to a Capcom Driver Board. Theoretically could it be done via the 34 pin data output rerouted/combined with another header to make a 50 pin connector.
