Hi,
I have a Capcom Airborne. All of a sudden I noticed that about 10 lamps didn't work anymore. It appears to be an entire ROW of lamps from the lamp matrix. More specifically, the RED/ORG row J1/2.3.
In the lamp test in diagnostics, when I select any of the non-working lamps, the display set the ROW.OFF= bright which according to manual means "A row driver is disabled from a ROW or BULB short circuit - The device was shorted and is now inactive (may be in a 15 second cool-down period)."
I checked each lamp for obvious signs of short-circuit, but all looks fine. I tested continuity on the complete RED/ORG wire from all lamps up to the J1 on the board, and the wire is working. So it's not a wiring issue.
What could I do next? Does it need board repair?
