I see it now, thank you! Still need a little more help.
1) Can someone tell me what component S10 on the Power Driver board is? Is there also a pre-driver for this component?
2) Is there something I can read, or a brief explanation someone can provide as a description of how the flipper circuit works on Capcom Breakshot? How does main flipper power and hold flipper power work? May be different than on the Bally / Williams games I own. Unfortunately, the Flipper Problems section of Pinwiki has no content at this time.
So here is what I see related to the right flipper (solenoid S10) working backwards from page 141 in the PDF copy of the manual from IPDB.
S10 connects to the Power Driver board via J14(6) a GRY/GRN wire (+50V), and also via J22(2) a GRN/RED wire (ground). Page 136 shows the corresponding wiring to/from the Power Driver board.
Page 130 is a wiring diagram of the Power Driver board. J14(6) is labeled as +50V for the right flipper, and it passes thru fuse FH8 and on to Bridge BR1. Bridge BR1 supplies power to numerous items and only the right flipper has been reported as malfunctioning, so we will focus our analysis on the ground side of the solenoid instead. (Hmm, unless the hum from the right flipper isn't really a part of the problem and something else that draws power thru FH8 is causing FH8 to blow, but the flipper coil shouldn't hum when the machine is powered on but no game has been started).
Page 128 is a wiring diagram of the Power Driver board and it shows connector J22. The text on this scan is light, so many things can’t be read clearly. J22(2) appears to flow to S10, but I can’t get a clear read of the writing surrounding S10 (or similar) on the diagram. Is this a MOSFET, and if so what is the part number for it? Is there any pre-driver for this component?
