(Topic ID: 294088)
Capacitor question.
By Drewscruis
2 years ago
#1 2 years ago
I'm working on a gottlieb jacks to open. I want to replace the capacitor in the cabinet. My question is, there are two 6800uf 25v caps in parallel. Now it's been a while since I was in school, but isn't the sum or 2 capacitors in parallel the total of their capacitance? So since they are 6800uf with 2 it should equal 13,600uf correct? Question is can I replace the two with just one 12,000uf 35v cap since it's pretty close?
#2 2 years ago
You’re correct, add the capacitors in parallel. However, go up just a bit in value, not down, to play it safe.
#3 2 years ago
Quoted from Drewscruis:
I'm working on a gottlieb jacks to open. I want to replace the capacitor in the cabinet. My question is, there are two 6800uf 25v caps in parallel. Now it's been a while since I was in school, but isn't the sum or 2 capacitors is parallel the total of there capacitance? So since they are 6800uf with 2 it should equal 13,600uf correct? Question is can I replace the two with just one 12,000uf 35v cap since it's pretty close?
You'll find 15,000uf capacitors commonly stocked. Also, make sure you get the same or higher voltage. 25v, 35v and 50v would work fine. When ordering, note the AXIAL or RADIAL wiring and usually easier to MATCH what you currently have. (the difference is wires some out both top and bottom, or bottom only)
1,650 (OBO)
Towson, MD
2,000 (OBO)
Woodhaven, MI
This page was printed from https://pinside.com/pinball/forum/topic/capacitors-question- and we tried optimising it for printing. Some page elements may have been deliberately hidden.
