Going higher in voltage is fine but this normally results in a larger capacitor body. Some are larger diameter and some are taller... and a myriad of combinations of both taller and/or fatter.
Three things to watch out for when replacing these caps:
1 -- lead pitch (spacing between leads). Most use 10mm.
2 -- maximum height of capacitor. Some of the higher voltage caps are taller and some games have problems with caps that are 50mm tall such as NBA Fast Break.
3 -- manufacturer matters. Avoid completely Chinese brands such as G-Luxon, Lelon, Capxon, Teapo, etc. Nearly all electrolytics are made in China now - even many Japanese ones. Difference is - the US and Japanese brands actually enforce quality standards (some more than others) - the Chinese brands only care about quantity and profit.
Ed
