@TomT, why do you need to replace that cap?
Chris Hibler - CARGPB #31
http://www.ChrisHiblerPinball.com/Contact ... for board repairs
Quoted from ChrisHibler:TomT, why do you need to replace that cap?
https://pinside.com/pinball/forum/topic/stern-rs-mick-motor-issue-
The original motor had issues to say the least and was blowing the fuse on startup the factory recommended changing the cap out with the new motor just as a precaution.
Quoted from TomT:The original motor had issues to say the least and was blowing the fuse on startup the factory recommended changing the cap out with the new motor just as a precaution.
I bought one of these a few years ago (not that vendor). Pretty amazing for $15. Tests transistors and FET's too (but struggles w/ Darlington configurations).
Comes in handy in this type of situation. Don't even have to hook up the test leads in any particular order - just connect and press 'test'.
I'd also look for a or pinched or shorted wire. And take a close look at the motor wire tabs - make sure they didn't shoved up against the motor case.
Pretty sure something internal went bad with the original motor it locks up and won't spin without a lot of effort and this is with it not installed in the gearbox.
Quoted from TomT:Pretty sure something internal went bad with the original motor it locks up and won't spin without a lot of effort and this is with it not installed in the gearbox.
Looks like you found the culprit!
This page was printed from https://pinside.com/pinball/forum/topic/capacitor-question- and we tried optimising it for printing. Some page elements may have been deliberately hidden.
