(Topic ID: 211883)
Capacitor Help
By Ohio66
6 years ago
  • 7 posts
  • 4 Pinsiders participating
  • Latest reply 5 years ago by JethroP
#1 6 years ago
Looking to replace a capacitor on the power supply in Banzai Run. In the manual it calls for a 100mfd, electr. 150V capacitor. On the power supply board the capacitor is a 100uf, 60V. Are these the same or which one should I be ordering?
#2 6 years ago
On that it shouldn't matter. But I'd replace it with what is in there now.
#3 6 years ago
Exactly which capacitors are you talking about on that board?
There are both high voltage and low voltage variations of capacitors on that board.
#4 6 years ago
Looking a capacitors C1 and C3, 100mfd 150V. I misspoke in the above post. On the board right now are 100uf 160V capacitors. My problem is I am not getting the +100 or -100 volts at 3J5.
#5 6 years ago
Yep, you need to stick with the 150V caps for that one.
Bad HV can be lots of issues.
First place to start is the 1/4A slow fuse F1 on power supply. Check with a meter rather than visually as a blown fuse can look good yet be bad.
For some good info -- see here:
http://www.pinwiki.com/wiki/index.php?title=Williams_System_9_-_11#High_Voltage_Issues_With_the_Power_Supply
#6 6 years ago
Removed the two capacitors C1 and C2 from the power supply board. Tested them with ohms test. Here is what I got. Red lead on positive side black on negative reading 4.43 ohns. Reversed leads readings are 1. on the meter. I take it that these are both bad?
1 month later
#7 5 years ago
100MFD and 100uF are the same.
$ 1,159.00
$ 18.95
$ 27.00
10,000 (OBO)
Thetford Mines, QC
$ 49.99
$ 279.00
$ 180.00
Displays
Digipinball Shop
$ 1,059.00
$ 169.00
$ 45.95
$ 1,280.00
$ 19.99
$ 54.99
$ 95.00
Pinball Mod Co.
$ 44.99
Pinball Shark
This page was printed from https://pinside.com/pinball/forum/topic/capacitor-help-1 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
