Has anyone else had this problem? I can adjust the volume above level 8 with no problems but it wont go below. Is there a setting I'm missing?
Quoted from Smurrill1:Has anyone else had this problem? I can adjust the volume above level 8 with no problems but it wont go below. Is there a setting I'm missing?
You have to go into adjustments and set the volume so you can lower it below 8. Forgive me as I do not recall the exact terminology.
There should be a minimum volume override in the adjustment menu. This is typical of the pins of that era.
Quoted from silverball0:There should be a minimum volume override in the adjustment menu. This is typical of the pins of that era.
Adjustment 1 -28 adjust minimum volumn turn to yes and your set.
I'm curious - Does anyone know why the "min volume override" issue/function exists? Why did B/W feel it was necessary to make it slightly difficult to go below a certain minimum volume?
Quoted from yzfguy:If it's too loud, you're too old!
I have found that the older I get the louder I crank it.
This page was printed from https://pinside.com/pinball/forum/topic/cant-turn-my-roadshow-volume-below-8-wtf and we tried optimising it for printing. Some page elements may have been deliberately hidden.
