Hello. I have a high pitched squeal coming from my Rob Zombie pin. I purchased it a few weeks ago and it didn’t make the squeal at the former owners house, but it does at mine. I think I isolated the issue. It appears to be the amp for the subwoofer. Simply put, if I turn it off the squeal goes away. If I leave the amp power on and unplug the audio cord to the amp, the squeal goes away. I believe it is a ground loop issue and I live in an older home. Here’s what I’ve done:
1. Tried different outlets, power strips, etc.
2. Played around with the positioning of the cables.
3. Tried a new audio cable.
4. Tried a ground loop isolator
5. Tried a different amp.
The only thing that has done anything is the ground loop isolator. It helps some but the squeal is still there.
Does anyone have any other suggestions as to how to fix the issue? I’m at a bit of a loss. Thanks in advance.
