Is the a dipswitch setting that may have been changed? Pressing the diagnostic buttons in the coin door do nothing.
What game ?
If Williams, check the CPU for battery damage, it gets the diagnostic stuff first.
LTG : )™
Any wires broken off of the diagnostic switches or the memory protect switch?
Any wires broken at the coin door connector?
I had a bad diagnostic switch on my High Speed. I ended up just shorting the leads with a flat head screw driver. Got the job done but not a permanent solution.
Toggle switch set to auto up. And push advance button.
If it doesn't work.....
Also check if any of the wires are pinched/broken in the bundle by the coindoor hinge.
If not, check the switch with a multimeter on buzz continuity.
See if it actually works/ closed when pushed. Check switch with the multimeter with the machine off.
And not exactly your problem but it might help troubleshoot
https://groups.google.com/forum/m/#!topic/rec.games.pinball/OQtJcqlQZ0Q
This page was printed from https://pinside.com/pinball/forum/topic/cant-get-onto-audit-mode and we tried optimising it for printing. Some page elements may have been deliberately hidden.
