New! Dark mode!
(Topic ID: 270884)
Can’t get into head gottlieb sys 80 star series
By rollinover
5 months ago
  • 14 posts
  • 6 Pinsiders participating
  • Latest reply 5 months ago by rollinover
#1 5 months ago
Trying to get into James Bond head
Guy I got it from left the game hooked up wirewise to the head ???
He started to drill the lock so it couldn’t even be picked
I’ve been trying to drill it out and turn crank it to loosen up the glass to come out and it’s not budging
Can someone offer some insight into this
Should I completely drill out the lock with a big drill bit ?? He seems to have hardened the metal inside the head
No slits in top and bottom access is limited as it’s still attached to the body
This is one strange situation but I’m looking for some help on how to open this gottlieb
I know certain widebodies use the latch and others have the hook in the bottom where you lift the whiteboard out
Either way I can’t get the backglass out to gain access
Any help is appreciated
#2 5 months ago
Might need a good cobalt bit, much stronger, chews through metal. Drill right through, a new lock is 5$
#3 5 months ago
Is that the best way for this head ?
#4 5 months ago
I have a small hole drilled all the way through on the end but still not turning
Well turning a little but still not turning enough to release the head
#5 5 months ago
Here is pic do i need to go bigger or how can I get this to release the backglass
It sounds like top of glass is touching metal lock
#6 5 months ago
I had a Robowar and the backglass was a pain to get out.
#7 5 months ago
Can someone verify which way the key should turn to get the glass out
Towards the front of the head the backglass or towards the back of the hood
One of the rougher heads I've dealt with and trying to be patient walked away twice already lol
#8 5 months ago
Buy a carbide tip drill bit like this and use a drill with an impact setting.
Champion Cutting Tool CT705-1/4X4 Carbide Tipped Locksmith Drill Bit amazon.com link »
#9 5 months ago
I use a 3/8 bit.It takes the guts out of the lock.
#10 5 months ago
Put a big flathead screwdriver in that slot then use a channel lock pliers for leverage to pop the lock . just some little tumblers in there
#11 5 months ago
Quoted from whizz:
You need at the very least a 1/4" or bigger bit then like plowpusher says, put a large flathead screwdriver in and turn clockwise.
#12 5 months ago
Thank you guys for the responses
#13 5 months ago
Now I know why he didn't disconnect the head and why it was strapped to the body lol
#14 5 months ago
Follow up on this
Worst lock ever came across
Took 3-4 times walking away in frustration
Drilled lock out more and that took a long time
Next inserted flat head
Twisted the flat and finally snapped loose
Success I thought
Nope flat head in the lock spinning 360 and still In the locked position
Guy before me must have gotten thru and it popped off the lock mechanism inside
After a good long look at it
I noticed one side seemed to be almost out At the bottom where the metal on the glass is
Even though it was in the lock position
I noticed I could just flex the bottom of the head wood enough to slide the glass out
This was a pretty risky procedure as there was decent tension on the bottom and top of the glass
But sure enough it worked and I got the glass out safely. I made sure to move fast but I’m not sure what else you could have done but cut a hole in the back of the head or something.
Thanks all for the recommendation
$ 8.00
Docent Electronics
Cabinet Parts
Flashinstinct
$ 150.00
$ 45.00
LightAndTimeArt
$ 259.99
$ 40.00
Arcade Arts
$ 295.00
The Art of Pinball
$ 7,599.00
Gulf Coast Pinball, LLC
$ 229.99
PinballBulbs
$ 159.99
$ 24.00
Pin Monk
$ 159.00
$ 49.95
Playfield - Plastics
MicksPinball
$ 29.99
Pinball Art Prints
$ 28.99
Lee's Parts
$ 29.00
Filament Printing
$ 23.00
$ 99.00
Lighting - Under Cabinet
$ 80.00
COINTAKER.COM
$ 60.00
$ 96.95
$ 22.50
Filament Printing
