(Topic ID: 112039)
Can't find the right plunger link assembly....
By nighttaco
  • 5 posts
  • 3 Pinsiders participating
  • Latest reply 4 years ago by jibmums
#1 4 years ago
I'm trying to replace the plunger link assembly in my Baywatch slingshot and it takes a link that's about half the thickness of most, can't seem to find that part anywhere.... any help would be apprecieated, thanks!
#2 4 years ago
Assuming you've found a plastic/nylon link that's correct but too thick, can't you just sand it down to a usable thickness?
#4 4 years ago
You know, the original looks just like all the others I've seen, grey link assembly, not the round white, although I may have to give that one a shot, appreciate you looking it up...
And as far as sanding it down idk, should be a cheap enough part to where I'd rather just buy it... not a bad idea if I can't find the right one though...
#5 4 years ago
Sanding may be a little tough if the link is still attached to the plunger. A Dremel tool with a cutting tip would work much better.
$ 22.50
$ 24.00
€ 339.00
Displays
GermanGamingSupplies.com
