(Topic ID: 129024)
Can't Add a location to Pin Map.
By Neal_W
  • 30 posts
  • 10 Pinsiders participating
  • Latest reply 4 years ago by
    There have been 6 images uploaded to this topic. (View topic image gallery).
    #1 4 years ago
    Trying to add a location in the pin map, but nothing happens when I press add location. I tried a month ago and got the error 'can't find location', now nothing happens when I press add.
    Maybe chrome is acting up??
    Vic's Kangaroo Cafe
    United States
    636 Tchoupitoulas St
    New Orleans
    LA
    Pin - TAF
    #2 4 years ago
    Nope, I cannot either. I stopped trying a long time ago. It is a site issue I believe.
    #3 4 years ago
    You actually have to find your location on the map, zoom in, zoom in and add the pin, you can't do it by your zip code or town name.
    #4 4 years ago
    I cannot either. I even tried using the address on the cross street of the store next door. Won't take that one either.
    I was able to edit existing locations and add a new location elsewhere with no issue.
    #6 4 years ago
    Have you tried to set manually?
    for a time I thought imcould just add my zip but it does not work unless you zoom in on the map to drop a pin.
    #7 4 years ago
    I don't see any way to drop it manually on the public locations page.
    #8 4 years ago
    Quoted from Chrizg:
    I can't update locations
    You need to uncheck the "Don't show Date Time Stamp" next to Save Changes button.
    #9 4 years ago
    Quoted from SealClubber:
    Where is that at ?
    #10 4 years ago
    Hmmm It must just only be a Moderator thing. It shows up just to the left of Close Location Editor button.
    #11 4 years ago
    You have to go to where it says 'set your location on the map' (note it doesn't work like you think, it won't work if you click 'set my location manually').
    then you have to zoom into your location (there is a circle on that is in the center of the map, you have to grab the map and put that circle where you want it. Then you hit 'proceed'
    #12 4 years ago
    I can't start a topic at all on pinside.
    I can type text into the topic line, but can't type anything at all into the "body" of the post.
    This just started happening since the last update a few days ago.
    #13 4 years ago
    Quoted from indypinhead:
    are you sure? Since the update, the new topic post, there is a very thin box that expands if you click on it so you can add text, it's not a full box like it was before until you click on it and type something.
    #14 4 years ago
    Thanks rai
    I got it to work.
    #15 4 years ago
    Quoted from rai:
    I'm not trying to add my location. I'm trying to add a bar on the pinball locator map.
    Give it a try. I can't add the following bar for example:
    Vic's Kangaroo Cafe
    United States
    636 Tchoupitoulas St.
    New Orleans
    LA
    Pin - TAF
    #16 4 years ago
    Quoted from Neal_W:
    Vic's Kangaroo Cafe
    United States
    New Orleans
    LA
    Pin - TAF
    sorry I don't know about that. I just went to a location said to have a Mustang pro, but there was no pins whatsoever so I'm going to see how to delete that entry.
    I go to delete the pin and it won't accept that I'm deleting the pin.
    #17 4 years ago
    I edited on Thursday but I haven't been able to since Friday.
    #18 4 years ago
    This still doesn't work. After updating the location, the 'Save changes to this location' button does nothing
    #19 4 years ago
    Please try after Robin pushes and announces new code tomorrow.
    #20 4 years ago
    Another related issue with adding and updating locations has been going on since the February update. It won't let you add or update if the location has an apostrophe in the title. It caused an error which says "Location Not Found" or something like that. So I had to start deleting the apostrophes out of location titles just to add or update. But yeah since the most recent update, I can't add or update anything at all, so hopefully it will all get fixed soon including the apostrophe bug.
    #21 4 years ago
    Once tomorrow's update is done.. If you still have the quote problem please open for a bug with that. Perhaps mention quotes in the topic. That is worthy of reporting separately to avoid it getting lost in the noise.
    #22 4 years ago
    Quoted from jfesler:
    Yes, I will sure do that. And technically it's not a "quote" problem. It would be any location name with an apostrophe; for example:
    Mick's Bar and Grill
    Moe's Sub Shop
    Joe's Old Town Bar and Grill
    Lucky's Everyday
    Larry Bud's
    Knolla's Pizza
    Betty's Too Laundromat
    John Barleycorn's Bar
    And all those are just in Wichita, KS. You would be surprised how many locations have an apostrophe in the title.
    #23 4 years ago
    My bad. From a language point of view you're right. From a programming point of view, it is a quoting and escaping problem; the apostrophe character is also know as single quote. the database language uses quotes - so quotes in values have to be handled specially.
    #24 4 years ago
    This one should be fixed now!
    #25 4 years ago
    Neal_W: Please mark this as resolved if you're satisified.
    Some of us are trying to use the resolved status to track things
    #26 4 years ago
    kst8cat: I'm filing detailed bug reports now for the quotes/apostrophes thing.
    #27 4 years ago
    I was able to update my locations.
    #28 4 years ago
    Awesome. Can you mark the thread resolved? IF you're on mobile, turn your phone sideways so this shows up at the top of the thread.
    #29 4 years ago
    I didn't start the topic so I do not have that option
    $ 38.00
    PinWoofer
    $ 90.00
    Lighting - Under Cabinet
    $ 69.99
    Metal-Mods
    $ 78.00
    $ 74.00
    Id Rather Play Pinball
    $ 89.95
    $ 8.50
    $ 7.65
    Cabinet Parts
    Third Coast Pinball
    $ 159.99
    $ 65.00
    Texas Pinball
    $ 3.00
    Various Other Swag
    Project Pinball Charity
    $ 45.00
    Just 3D Mods
    $ 11,500.00
    PinWorlds
    $ 5,799.00
    Classic Game Rooms
    $ 80.00
    Latenight Weeknight Mods
    $ 7.50
    $ 39.50
    $ 42.00
    The MOD Couple
    $ 48.00
