I was wondering if anybody could help me. The large gobstopper in my machine has stopped rotating when you hit the gobstopper target. It was working a few days ago and it’s just stop. It’s not a fuse because the lock ball still rotates properly. I have done a coil test and it doesn’t seem to do anything. Does anybody have any ideas or suggestions?Thank you so much!
Quoted from izboy:Does anybody have any ideas or suggestions?
Did you check connectors under the playfield ? I know you check that the connectors were seated on the I/O board.
Next thing would be put a motor and see if you are getting 12 volts DC or not. If so suspect the motor. If not, check continuity of each wire back to the I/O board.
