I fixed mine with JB weld, but only had the two end welds break loose, not the entire bar like yours.
You can re-spot weld it (done in seconds), or epoxy it.
If you epoxy, make sure you rough up the 2 surfaces with 80grit, and clean the hell out of it before gluing.
jewlery stores have laser welders.they can weld it back togeter with very little heat and no discoloration for a permanent fix.
http://www.pinballlife.com/index.php?p=product&id=2713 If you can't fix it good, they are available.
Quoted from joekiss:Any idea how much it would cost to have welded?
TIG welding would probably be $15.
Tell the alcoholic at the welding shop that it is from a pinball machine; he might give you a discount if you listen to his pinball story.
Quoted from vid1900:Tell the alcoholic at the welding shop that it is from a pinball machine; he might give you a discount if you listen to his pinball story.
Wow - I don't force my pinball story on anybody! LOL
I have a TIG and spot welder in my shop, but honestly I would just epoxy the parts back together if I were in your shoes.
The risk of burning through is just too great for thin metal parts like this (i.e. making a hole in metal). The problem with a welding shop is they may put the flunky/trainee on the job because if it fails it is not a big deal. Overheating Stainless steel is really easy when welding.
There is so much surface area on these parts it would be very easy to get an excellent glue job with the cheapest of wal-mart epoxies. As Vid said, sand the surface, clean with alcohol or other degreaser and glue them together. You will use a $1 worth of glue and half and hour of your time to do the job well. It will take you at least that long and more money to go to a welding shop and get them to do the job.
Most epoxies have strength in at least the 100's of PSI. Start to add up the square inches on that lockdown bar. That glue joint if well done would need 1000's of pounds of force to break it apart.
Quoted from mg81:Most epoxies have strength in at least the 100's of PSI. Start to add up the square inches on that lockdown bar. That glue joint if well done would need 1000's of pounds of force to break it apart.
Very true, and worst case scenario, if it doesn't hold you can just sand/grind off the epoxy and your back in the same place you are now.
This page was printed from https://pinside.com/pinball/forum/topic/can-this-be-fixed-1 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
