lotr. don't have a manual handy..
#53: flipper adj 1 (default 20)
#54: flipper adj 2 (default 50)
#55: flipper adj 3 (default 3)
anything to do with strength?
thanks!
-jon
thanks!
-jon
thanks erik!
that's some odd settings for sure...
so if my issue is that even with the flipper coil strength set to "low", the flippers are too strong, then i guess my best bet is to set all three of those fine adjustments as low as they go? or somewhere in that vicinity?
-jon
Quoted from bigehrl:thanks erik!
-jon
From what I've seen adjusting the "coil strength" menu setting is for all coils other than flippers, I didn't notice any change in the flippers.
I switched to the PB life coils a few weeks ago after dealing with flipper fade after trying everything for the last 7 years. Is that what you did?
I turned the first two of those settings to 10 and 40 and it made a noticeable difference, might try that! Doesn't hurt anything to try anyways.
This page was printed from https://pinside.com/pinball/forum/topic/can-someone-please-explain-these-lotr-flipper-settings and we tried optimising it for printing. Some page elements may have been deliberately hidden.
