AC/DC Premium has three LED subsystems.
1) RGB LED and GI - deliver 4 channels of GI and 16 channels for RGB. This board is controlled by the serial port on the CPU board - not the power-driver board.
2) Serial LED system, replacing the lamp matrix. This system feeds a string of boards that either have the LEDs and serial controller on the board, or also feed separate LED lamps mounted individually. I just replaced my AC/D target insert boards with blue LEDs to get the color to look bluer - the white LEDs blow through the blue, making it more of a tint than a color. Pics here: http://smu.gs/Ovc9ER
There are no longer any lamp matrix connectors - the LED system is controlled by an FPGA on the power-driver board.
3) The flames board, which uses the strobe and data interface from the power-driver board.
The target insert on the left has a blue LED underneath it. The left center insert is a light blue, and the right is an original white LED.
So, I've read that Stern switched to serial LED controllers rather than using the lamp matrix, and best I can tell it was between Tron Pro and TRON LE. Correct?
Anything after then will have LEDs from the factory and no option to use incandescent bulbs, correct?
Any idea what the new Tron Pro machines will have?
