I checked the voltages:
R55 - across = 4.6v ; bottom leg = 1.4Mv ; top leg = 4.6v
R51 - across = 74.5v ; bottom leg = 5.8v ; top leg = 1.3 Mv - I checked each point twice. But the second try on R51 - top leg I got 190 Mv and it was fluctuating (like an open circuit)
Then I checked the banded side of VR1 and get 200 Mv - fluctuating.
Then I checked the displays and they were all dark. I'm not sure but I think they went dark between my first and second attempt at R51 top leg.
Back in post 15 Quench suggested I check the solder connections on C26. I looked at the solder joint on the back of the board and it looked fine. (I didn't check continuity)
After the displays went dark I pulled the board and took it to the bench. This time I did continuity check the solder connection on the top of the board. It showed open from the + leg of C26 to TP4. I re-soldered the connection on the top of the board and now I have continuity to TP4.
This was probably the problem all along. I just hope something else isn't causing the dark displays now. I'll try another driver board and check the displays. Then I'll install this board and try again.
I'll let you know what happens.
Bob
