Can-Not get an old Can-Can to start up
(Topic ID: 209756)
By Bingo-poor
11 months ago
  • 19 posts
  • 6 Pinsiders participating
  • Latest reply 11 months ago by baldtwit
    #1 11 months ago
    Machine tilts on first coin played....any ideas out there?
    #2 11 months ago
    is the tilt trip relay tripping or is the anti-cheat relay not powering/staying powered?
    you should be able to turn on the game and manually push down the anti-cheat relay armature/plate and it stays down.
    #3 11 months ago
    The anti-cheat armature relay plate is energized and staying down as soon as I power the machine up.....
    #4 11 months ago
    The tilt trip relay trips as soon as I try to start a game
    #5 11 months ago
    Verify none of your cabinet tilt switches are engaged. Most likely the 'plumb-bob' sw.( lower left),
    if you have one.
    Or.......... Relay bank switches mis-adjusted.
    ***** I disable all my cabinet tilt switches, but that's just me.
    #6 11 months ago
    If you are manually tripping the coin switch, make sure you flip it really fast as though a coin were going over it. Any delay will trip the anti-tilt.
    #7 11 months ago
    Good call Dennis
    Noticed that when I got started on my machine.
    Terry K
    #8 11 months ago
    I have already checked all the tilt switches. I have it wired for free play at the red button via toggle switch wired to
    48-2 and 50-2 at the front door plug (per instructions on the “bingo cdyn” website). I will check again for mis-adjusted
    Switches at the trip bank and let you guys know where I am with it.....thanks for the responses
    #9 11 months ago
    if the anti-cheat relay is powering when the game is first turned on, I assume switch C on it is misadjusted permanently closed? That's one way to prevent credits from resetting at power-on.
    if you can manually reset the tilt trip relay by lifting up the armature and it stays in the untripped position, all the slam switches and pendulum bob are ok and the problem is likely the CU 4D switch. It's acting like it's MBB (make-before-break) ... in other words, during it's operation by the cam all three blades are touching each other at the same time. You need to adjust that switch so the center/moving blade disconnects from a surrounding blade before it touches the other surrounding blade. If the moving blade connects wire 13-9 to 14-5, you'll trip the tilt trip relay.
    if you want, you could just bend up the top blade on CU 4D so the center blade never touches it. That would disable the "tilt when the coin switch closed too long" circuit and also fix the MBB issue.
    #10 11 months ago
    Quoted from baldtwit:
    One of the first things I do to every bingo. Not needed in a home environment. Unless you're charging people to play and they have cheating on their mind.
    #11 11 months ago
    Checked switch C on the anti-cheat and is set correctly (NC) Also bent the blade up at CU cam 4-D. The anti-cheat is still energizing at power up and the machine still tilts at first cycle.....If I try to manually reset the tilt trip, the mixer #2 relay coil buzzes like hell and the tilt trip will not reset.
    #12 11 months ago
    My mistake, switch C at the anti-cheat is set correctly (N.O.)
    #13 11 months ago
    This is what I would do to start...........
    1. Put Credits on your Bingo.
    2. Un-solder the hot lead from the Tilt coil to disable it ........ troubleshoot that problem later.
    3. Forget about the Coin mechanism.........like Dennis said ; or come back to it later.
    **** See if you can get to the Start condition and Go from there.
    @ I'm sure you will have many other problems, but you might be able to Play a game or two.
    #14 11 months ago
    has the game always done this, or did it just start?
    the anti-cheat relay isn't particularly important...maybe. The only other ways the anti-cheat could power is:
    - CU 5C is closed and the EB trip relays aren't tripped. You could manually trip the EB trip relays then turn on the game and see what happens.
    - someone changed the circuit or you have a short
    if CU 5D is closed and the switch stack is sitting up on a cam lobe, the maybe part kicks in. Why is the stack being lifted?
    to narrow things down, if you manually reset the tilt trip relay then turn on the game, what happens? If it trips, it may be worth stuffing some paper under the anti-cheat armature so it can't close and try again. if it still trips, you've got a stuck slam switch, pendulum bob, short or plug installed incorrectly in a socket as mentioned above.
    the mixer #2 relay buzzing is common. As soon as you untrip the tilt trip relay, wire 30 is connected to wire 21-3 and much of the 50V circuit can be active. You can try removing the relay armature and whacking it with a hammer on an anvil to flatten it/remove dimples, swap the armature with another relay, swap the coil with one that's not powered as long/often, fiddle with the coil top if it's worn, or replace the coil.
    #15 11 months ago
    Just chiming in late here, without checking the schematics, but with the free play method used, couldn't a mistake have been made regarding which pin the toggle switch is soldered to?
    One of the switches on the door is a punch/kick/slam tilt. Solder bridge could also do this... just a thought. You're in very good hands - feel free to ignore me.
    EDIT: Now I see in baldtwit's post above that he references a stuck slam switch. Just another potential source of 'stuck' that isn't obvious.
    #16 11 months ago
    Nick, That's Funny!
    #17 11 months ago
    I took JKnPA’s advice and removed the hot lead from the tilt trip coil and have been troubleshooting/ fixing issues, for the last couple of days.
    I’ve got it down to few that I can’t seem to figure out.
    1. The blue button advances scores and features and the green button does likewise.
    2. The 64 odd OK game when hit: advances to after the 5th (which I am pretty sure is wrong) and the selection feature step up coil go’s crazy and keeps stepping up. Punching off a game will stop this madness,but what the heck? Then to add
    Insult to injury it does not light the yellow super section.....
    3. A few random score lights (as in 2 at one time) on the red and green odds from 4 to 8 odds, some times they disappear as the odds advance and sometimes they don’t.
    I appreciate you guys more than you know and your knowledge of these machines amazes me.
    #18 11 months ago
    Misaligned wipers on red score unit would have that effect for the lamp. Wish I still had a screen game to verify, but if there are zero and Max position switches on selection feature unit, check them for proper adjustment and operation.
    #19 11 months ago
    1] the switches behind the buttons
    there's multiple switches on the stacks behind each button. One of the switches on each stack - usually the middle one - causes the start relay to power. That switch needs to close as late as possible in the button travel.
    You should be able to push in the colored buttons partway and have the lit panel change to that color, then let go and change to a different color without the game cycling....at least for red, green, blue and white. if you are doing it later with yellow, you can probably only flip between yellow and red.
    Adjust the button switches to make that happen and see if the blue and green work right. The goal is to have the play scores (blue), play features (green), or play superscores (white) relays power before the start relay does. For the red button, none of the those relays should be powered.
    2] on can-can, the red letter feature unit in combo with the other score and feature units causes the stop relays to power at the right time. Take a look at the upper right corner of the schem.
    If the selection feature unit is stopping at the right place sometimes but not others, a wiper/rivet connection on the red letter unit is likely bad.
    the OK sequencing happens around A-G33 on the schem.....red, yellow, magic screen, selection and finally score booster. If one of the stop relays in that sequence doesn't power, the rest of the OK setup never happens.
    in your case, if the selection stop relay doesn't power, the selection feature unit will step forever. The yellow score booster trip relay won't trip either.
    cycling the game causes the pos 29 relay to open...that does abort the OK game setup sequence.
    3] as bpc said, the wipers need to be centered (more or less) on the rivets at each step. If you bridge to an adjacent rivet, you're sol. If, however, you are also getting other lights stuck on (like feature lights), usual cause of that is a spotting index switch stuck closed.
    generally you can't bend the wipers on a stepper unit to align them onto a rivet. The way the wipers mount on the center hub guarantees correct alignment unless someone mangled the wipers.
    if all the wipers are off the rivet centers the same way, you need to loosen the screws fastening the contact plate to the unit frame and rotate the contact plate (do this with the wipers on step 1+...the reset position has more slop in where the wipers are). It's okay if the contact plate is cocked wrt to the unit frame, just make sure the wiper contacts are as centered on all rivets as possible.
    $ 86.95
    $ 14.00
    Lighting - Under Cabinet
    $ 7,499.00
    Classic Game Rooms
    $ 7.95
    Various Novelties
    Pinball Wheezer
    $ 11.99
    $ 49.99
    $ 29.99
    $ 36.99
    Lee's Parts
    $ 90.00
    $ 28.00
    Pin Monk
    $ 5,599.00
    Gulf Coast Pinball, LLC
    $ 8,500.00
    Classic Game Rooms
    Pinball Photos
    Pin Monk
    $ 89.95
    Apparel - Unisex
    Project Pinball Charity
    $ 60.00
    Mods for your pinballs
    $ 76.95
