(Topic ID: 197107)
Can I use the small screws in place of the big ones
By zr11990
5 years ago
    #1 5 years ago
    I am finally swapping my Earthshaker PF with the NOS one I have had for years. Looking at the big screws that are used for things like flipper plates and thicker metal parts they almost go all the way through the PF. I decided to us the smaller screws like the gold ones that are used on light sockets and other smaller things. Can I do this and will it hold if I do?
    #2 5 years ago
    Those would probably rip right out of the wood. If I recall, the lamp socket screws are a smaller diameter.
    You could probably get away with slightly shorter screws, as long as they are the same diameter.
    Boltdepot.com and fastenal have a wide selection of screws if you need some.
    #3 5 years ago
    I wouldn't. They're too short. If you're using the same size as the factory hex heads, they shouldn't be poking through the playfield.
    #4 5 years ago
    light sockets and thin metal are usually #6 x 3/8"
    https://www.titanpinball.com/index.php?route=product/product&path=58&product_id=93
    Brackets thicker that the light sockets that don't hold coils, magnets, or anything heavy are usually #6 x 1/2"
    https://www.titanpinball.com/index.php?route=product/product&path=58&product_id=94
    Flipper brackets, coil brackets, and all the thick stuff are usually #8 x 1/2"
    https://www.titanpinball.com/index.php?route=product/product&path=58&product_id=92
    BTW, i finally found the correct screws without the slots in the heads. I need to update the pictures on our website
    This page was printed from https://pinside.com/pinball/forum/topic/can-i-use-the-small-screws-in-place-of-the-big-ones and we tried optimising it for printing. Some page elements may have been deliberately hidden.
