I have an Aztec, the alternator is messed up, is there a way I can jump it to the spinner until I can replace the alternator?
Quoted from NextoPin:I have an Aztec, the alternator is messed up, is there a way I can jump it to the spinner until I can replace the alternator?
Nope. Recall that a spinner always comes to rest with the switch in the same state. An alternator is supposed to change state from make to break, etc.
It's surprising how many WMS EM games of this era are missing that part.
Chris Hbler - CARGPB #31
http://www.Team-EM.com
Quoted from NextoPin:Could I stack the switch on one of the score motor cams?
You'd have the same problem. The score motor always returns to the same state.
Generally, the alternator circuit scavenges off the 10 point relay and perhaps some other combination.
You =might= be able to take over the 10 point reel's match feature contacts, but of course, that would only work for that particular player while that player was playing since Aztec is a 4 player game. And, you'd lose the match feature if that matters to you.
Chris Hibler - CARGPB #31
http:/webpages.charter.net/chibler/Pinball/index.htm
Quoted from swampfire:EDIT: really, there's an alternator in EMs? I'll shut up, sorry.
I think Williams calls it a "change" unit if we're talking about the same thing. My buddy Vic found an awesome all original "Blue Chip", but someone had amputated this part out of it. He has since found one and installed it. It alternates lanes and pop bumpers on the playfield, and also selects the match numbers.
Maybe piggy back it on a vertical switch behind a rubber ring? With insulator and riser/standoff post.
The 'alternator' is this little gear with a switch that rides on it. When the ball hit's the switches on the sides of the rollover lanes it advances the gear and opens and closes the switch changing what features are lit such as the upper 2 or lower pop bumper and some of the bonus advance switches and rollovers.
Here's a pic of it. after looking at it some more, I think I can repair it, I thought it was a stripped gear, it might just be a tension spring.
alternator.jpgI think I got it working at least mechanically. There was a tension spring on the back of the center "gear", I adjusted that slightly and now it makes it all the way around where before it would stop on one of the faces. You can see the spring just below the screw in the center above the shaft.
When I move it manually it doesn't do anything, but if I manually press the change relay it will alternate the bumpers and bonus shots. Still need to do a little more digging, but almost there!
Dear NextoPin
The "Tension spring" You say - actually is a "Stop for NOT turning around the axle the wrong way". Loosen the two screws (seen in the pic exactly in the middle of "Left <-> Right") now You can move that metal blade ((pointing to the little black plastic "wheel")) back and forth. Pull it back (on the picture: push it away from You) until with a little klick its resting under a "Notch" / "tooth" of that little "wheel". In this position the axle can NOT turn in the wrong direction.
"Axle turning in the right direction": a "Point" on top of the White "Wheels" (left and right) will turn away from You - the direction the thing is moved.
"Axle turning in the wrong direction": a "Point" ... will turn / come towards You / will come closer to You. Greetings Rolf
I fixed it!
I determined that the change relay was not being energized. The change relay is turned on by a switch similar to the alternator pictured above that sits between the 2 match unit boards, the switch was bent and dirty. I tightened the screws on the switch, cleaned the contacts and now it's working! My first 100% working EM! Awesome.
Martin, I had this thread up on my screen and didn't see your update. That's exactly how I adjusted it to enable the alternator to rotate (step) completely around, but that was just part of the issue. When I pressed the switches on the playfield to "alternate" the bumpers and bonus lanes the alternator coil wasn't firing. It fires through the change relay but that coil wasn't firing either, in the end, it was a switch adjustment on the match unit.
This page was printed from https://pinside.com/pinball/forum/topic/can-i-use-a-spinner-in-place-of-an-alternator and we tried optimising it for printing. Some page elements may have been deliberately hidden.
