can I put new code files on the same usb stick and use it to update games? Dealing with mostly the newer files, Iron Maiden, Aerosmith, GOTG, etc.
yeah, i want to add put multiple games on one stick... so I don't have to carry around 5 different usb sticks.
Quoted from MaxPinball:yeah, i want to add put multiple games on one stick... so I don't have to carry around 5 different usb sticks.
I have never actually tried it, but they tell you the stick has to only contain the files for the game...no idea what would happen if you actually tried it; probably just sit there doing nothing.
Only one way to find out
Quoted from MaxPinball:can I put new code files on the same usb stick and use it to update games?
Yes I do it all the time, the only problem you may run into is if you accidentally install the wrong code on a machine...I know I put GOTG on the wrong machine once (Star Wars maybe, I don't recall)...about 10 - 20 seconds into my play test I said " Wait a minute..."
When you boot the machine with the USB stick in, there will be an option to choose what code you are installing.
EDIT: This obviously will not work for a FULL install on a Jersey Jack or CGC pinball as the stick is formatted to boot into a linux OS.
Quoted from Pin_Guy:Yes I do it all the time,
Nice. Save me a little time next go around.
Quoted from Pin_Guy:Yes I do it all the time, the only problem you may run into is if you accidentally install the wrong code on a machine...
FWIW, I have had problems on SAM games using a drive over 8GB. I'm pretty sure, for whatever reason, when I used a 16GB drive it caused the install to fail.
I used a 32 GB stick on a Spike game and had no issues...
Quoted from buffaloatx:FWIW, I have had problems on SAM games using a drive over 8GB. I'm pretty sure, for whatever reason, when I used a 16GB drive it caused the install to fail.
I've heard this from more than one person, I don't know why this is. I use a cheapo SanDisk Ultra 32GB drive I picked up from Walmart for <$20 and it just works with everything. Except for Batman 66, that machine always locks up at a random point on the first try, but completes fine every time on the second...that's a weird one.
(Stern back box key and quick release key chain not included)
Quoted from Pin_Guy:(Stern back box key and quick release key chain not included)
I'll trade you a tasty beer for the quick release...
This page was printed from https://pinside.com/pinball/forum/topic/can-i-put-multiple-stern-codes-on-same-usb and we tried optimising it for printing. Some page elements may have been deliberately hidden.
