(Topic ID: 112174)
Can i get #63 flasher bulbs at autoparts store?
By jcar302
5 years ago
  • 12 posts
  • 7 Pinsiders participating
  • Latest reply 5 years ago by KevinD
#1 5 years ago
Hey guys, I have a few flashers out on my high speed, the right side hideout was out and after I few searches I found out that these run in series, I had one so they are fixed, but the ones at the top of the playfield have been out since I purchased the machine, so i'd like to just change them all. I may goto leds on them, but I don't want to complicate trouble shooting, so i'll do that after they all work.
Didn't see them on radioshack site and the one I drive by all the time is closed. I could go further to another if I have to.
I know they are cheap online, but i'd like them sooner than later and have no interest in paying $25 to have a set of $5 bulbs over nighted because I lack patience.
If I have to wait, it's not the end of the world but if there is a source that usually has them it would be good to know.
During an ebay search they come up as parking lights on some cars, is this true?
#2 5 years ago
I had a friend that worked in an auto parts store and he got me a lot of the bulbs that I needed except LEDs.
#3 5 years ago
Yeah they will have them. I put some LEDs in my friends HS but stuck with the incans for Flashers, I think they look much better and #63s are really bright. The only ones I replaced were the ones in the backglass behind the tailpipes, and I got them at an automotive parts store. They were $5 per 2 pack, so a lot more money than buying them in bulk from the pinball places but they do look great. Next time I place an order I'll probably grab a 10 pack to keep around for when the playfield/radar detector ones start going out.
#4 5 years ago
Thanks guys, on your advice I stopped got a couple at pep boys, they wacked me $5 for the 2, that will keep me going, ill order a box next time I make a pin order.
#5 5 years ago
Yes # 63 bulbs are commonly available at any auto parts store.
#6 5 years ago
You can use #89 bulbs, a little dimmer but last a very long time.
#7 5 years ago
I changed them out, but the top flashers (top as in top of the playfied) still don't work at least during testing. The coil test cycles so fast that I pretty much have the pattern memorized.
#8 5 years ago
With the glass off you can just get it to the run red part. Makes it easier to test.
#9 5 years ago
I had the same problem on my HS. Turned out to be a broken lead on a ceramic resistor under the playfield. I ordered 63s from O'reilly auto parts. $3.99 for a box of 10. http://www.oreillyauto.com/site/c/detail/EIK0/63.oap?ck=Search_63_-1_1845&keyword=63
#10 5 years ago
Quoted from KevinD:
Thanks,
I'll check it out, they still don't work.
3 weeks later
#11 5 years ago
Quoted from KevinD:
Had some time today so on your advice I starting looking through the resistors.
Sure enough on the larger 5ohm one leg was broken.
I tried to solder it with a short leg and what a bitch that was. Didn't get it done, so I crudely tied the long leg to the short leg for now, sure enough it works.
Because I have freeplays clear ramp, I think I need to switch the left bulb to red or blue.
Thanks for the help,
Joe
#12 5 years ago
I'm a noob at this stuff and that was the first thing that I figured out and fixed on my own. I'm glad that I could help someone else for a change. BTW if you do change that resistor, the only ones that I could find are 5.1 ohm.
$ 54.99
$ 164.99
PinballBulbs
Gweem's Mods
Trade
Machine - For Trade
Massapequa, NY
$ 29.99
PinWoofer
$ 60.00
RobTune
